Help Efilive Wb ?
Old Sep 2, 2008 | 08:25 PM
nnracing's Avatar
Default Help Efilive Wb ?
I Have A New Ngk Afx Wb And Am Trying To Calibrate It To Work With The Efilive Scan Tool But When I Calibrate It Too The Correct Voltage Via 1 Battery And Then Two Batteries It Is Not Accurate, Anyone That Is Using One With Efilive Please Help, Also Need A Ben.cal Pid So I Can Autove Need Help With That Also.
Old Sep 3, 2008 | 11:11 AM
wait4me's Avatar
Did you try posting on the main efilive forum? There are tons of people there that have exact settings they did to make them work.. www.efilive.com
Old Sep 14, 2008 | 11:20 PM
shoemike's Avatar
this has PIDs for the NGK Powerdex AFX WBO2.
calc_pids.txt
the PIDs are for GASOLINE.
