Edit v1.3 Timing vs Temp Table
Old Sep 4, 2003 | 07:37 PM
XtreemeChaos's Avatar
Default Edit v1.3 Timing vs Temp Table
Anyone have any luck messing with this yet? I just got my update and took a look at it and at some points when it is cold, it is removing up to 8 degrees of timing. I think this is why alot of people have problems with cold starts after installing a cam. I set everywhere that was taking timing away to 0. I guess I'll see in the morning if it helps cold starts.
Old Sep 4, 2003 | 09:39 PM
Darkhalf's Avatar
Default Re: Edit v1.3 Timing vs Temp Table
Let us know if that does help. My car has a heck of a time idling when its cold. Basically it will idle high at 1000 rpms when cold set via edit. But once I blip the throttle it goes down to 400-500rpms and just stays there until it finally warms up to normal operating temps.
Old Sep 4, 2003 | 11:32 PM
URPREY's Avatar
I finally flashed my car tonight using that new table. I zeroed out all negative numbers from -20c to 40c. That corrected my hunting idle problem while in open loop
Old Sep 4, 2003 | 11:40 PM
Bink's Avatar
Very
joel
Old Sep 5, 2003 | 05:18 PM
Cal's Avatar
Cal
I'll be trying that tonight as well, just got my 1.3 update. I have thought for a long time we would have a great cold idle with another 5 degrees of timing; you can see it jump up at 100*F (40*C.)
Old Sep 5, 2003 | 05:35 PM
URPREY's Avatar
Yeah, I've seen your posts about that using search on that very topic. It definitely fixed mine
