Need Help Asap!!!
Old Sep 7, 2008 | 06:01 AM
Black FormulaLs1's Avatar
Default Need Help Asap!!!
my speedo quit working...please help asap!!! i need this fixed!!! am checking fuses now but so far no luck!!! could it bbe a fuse or a sensor?
Old Sep 7, 2008 | 09:53 PM
wait4me's Avatar
Your Speedo or the complete dash.
If just the speedo, you need to plug into the obd2 port with a scanner and see if it is showing vehicle speed thru the computer. if it is, then there is a short or bad ipc.
If it is not showing anything in the scan tool, then it is a burnt wire, disconnected wire, or bad speed sensor.
