Anyone using Edit with Vista
Old Sep 8, 2008 | 06:13 PM
B.Buster's Avatar
Question Anyone using Edit with Vista
Having probs with Edit using Vista .Only a few USB to serial adapters work with Vista.Having probs connecting.Sometimes it takes up to 10 tries to connect or not at all.Thanks in advance.
Old Sep 8, 2008 | 07:50 PM
rickou812's Avatar
I am using edit with vista with an adapter.
I had to get the latest version of edit though to work with vista.
The adapter I am using is a standard radio shack adapter...
Old Sep 9, 2008 | 04:26 AM
B.Buster's Avatar
rickou812, does yours make connection on the first try or does it take afew ?
Old Sep 9, 2008 | 09:04 AM
wait4me's Avatar
Are you running the program as administrator?
Old Sep 9, 2008 | 10:43 AM
rickou812's Avatar
It depends, I have noted that when I go from autotap back to edit, I have problems reconnecting unless I unplug the USB cable from the computer and replug it in. I think it has something to do with the drivers that loads. The laptop does not see a change in equipment since we are using the adapter. At least that is my theory.
I do not have any issues connecting if I start fresh every time, (i.e. Unplug the adapter from the laptop and then plug it in and checking the com port it has chosen) . I use com 1 just to make my life easier so I do not have to change it in edit.
Hope this helps,
Richard
Old Sep 9, 2008 | 08:31 PM
B.Buster's Avatar
Wait4Me, I was running as admin.
