Idle - Dies at stop, ok when rolling.
Old Sep 9, 2008 | 01:00 AM
kelp's Avatar
Default Idle - Dies at stop, ok when rolling.
C6 Z06. HPTuners:
After 10-5 secs idle suddenly dies down then comes back up. Sometimes it dies completely. But if the car is ROLLING 2 mph it idles PERFECTLY. The closest table I find that differentiates idle from a stop and a rolling is OL & CL > LTFT Idle Cell > Enable VSS and Disable VSS which I set to 0 mph. I have been working on this for a month. Any tuners have any suggestions on tables to alter?
Old Sep 9, 2008 | 08:57 AM
LS1-450's Avatar
Sounds like commanded timing or an anticipated airflow problem. Check timing & anticipated airflow settings, as well as, timing & anticipated airflow modifier tables for IAT, ECT, airflow during idle, idle mode identified TPS position. Also, have a look @ your MAF table & make sure it is tuned correctly. Good-luck
Old Sep 10, 2008 | 08:50 PM
kelp's Avatar
Perhaps so. Parameters logged are all ok at "1" mph, and then switches completely at "0" mph, foot off the pedal all the time, going way lean, and dying every 10-15 sec.
Question is, what table switches this. I am looking all over for this switch - it may be in the BCM (and not accessable???)
Old Sep 11, 2008 | 06:43 AM
BLK02WS6's Avatar
It needs more running airflow at idle - it is getting the airflow it needs from the throttle cracker table (which shuts off at 1mph when stopping), but you don't have enough in the table that controls idle airflow while sitting still.
Old Sep 11, 2008 | 07:12 AM
Gh0st's Avatar
Jedi Master
this
Old Sep 11, 2008 | 08:12 AM
Engine_HP's Avatar
try increasing ur Base Running Airflow should be from 13 to 17 not more and set ur idle spark to 22 and ull be fine.
Old Sep 12, 2008 | 09:23 PM
kelp's Avatar
OK I increased the Final Idle Airflow until it didn't die anymore. (also tuned the MAF so the g/cyl was just right).
Now it idles at 1500, ignoring the Target Idle.
Since it's an LS7 I can't get at the throttle cracker table. I would love to make it think it was moving all the time.
Old Sep 13, 2008 | 01:11 PM
Gh0st's Avatar
Jedi Master
Sounds like you have way too much RAF. I typically run no more than 9.5 at operating temps
Old Sep 13, 2008 | 01:59 PM
kelp's Avatar
Got it. MAF, etc did need some adjustments, I returned the FIAF to the previous adjusted tune. The key was in the min ETC settings, kind of like what the cracker does. Very perfect and wonderful result.
