High intake temperatures - ideas.
I bought a different type of sensor to try out, and I may even try a different location for the sensor. The factory sensor is plastic bodied and mounts in a grommet in rubber. My sensor is metal bodied, and mounts in aluminum. I think this is the root cause of the problem. The aluminum is transfering heat to the sensor body, causing incorrect readings. I'm going to try out the factory sensor, and maybe even move it to a diff location.
Here is my intake setup. What is not pictured is that it is now header wrapped. I overlapped the wrap 3/4 width on each wrap, so its probably equivalent to double wrapping it. I used two 50' rolls on the intake.
It should have several layers of heat protection. Ceramic coating, aluminum pipe, ceramic coating, and double thick header wrap. This is the reason I belive the temp sensor reading to be erronious. I am considering not even putting the sensor in the intake, but putting it down in the cavity where the filters pick up air from. Thoughts? Currently the sensor is in the Y where the two sides come together, only a few inches from the throttle body.
I cannot use COS5 with my PCM. There is not a COS5 for an 04 GTO PCM. Which pretty much sucks, and I've petitioned to have them create one for over a year now. What does A0014 table do? I figure I coudl also modify the IAT timing table to not pull timing, but I don't think I'm real keen on that idea.
What I've done with my Camaro (speed density, full time open loop) is move the IAT sensor to a little black box I keep behind my headlight. My fueling stays more consistent overall (especially when idling in traffic) since the IAT sensor is reading a more accurate ambient reading than sitting in the intake tract around lots of hot stuff.
It might be a girly car but I bet it goes.
What I did is relocate the sensor down be low the radiator. You need to find a place that does not heat up when the car sits still. The air going to the engine at idle travels down the center of the pipe. There is very little flow at the side where the sensor is. If the pipe heats up the element that in the center of the cage get hot and reads hi. If you find a sensor that is longer and goes deeper in the pipe with a smaller element there will be less of a problem.
What I did if find a place that did not heat up during sitting. The radiator adds the most under hood temp. Heat rises so if you mount the sensor below it and in the intake airflow I think that is the best you can do. There are just 2 wires to extend.
Good luck
All in all I consider this a big improvement. 15 degrees over ambient vs 65 degrees over ambient. The 15 degrees over ambient I think is actual temp of the air entering the filter. The IAT drops within 15 seconds of getting the car moving, so I think its real.
Success is mine! LOL!
Reason I am asking is I have heat problems 90% of the time in our weather lol
