Need your help on problem.
Old Sep 14, 2008 | 07:40 PM
99SSragtop's Avatar
Default Need your help on problem.
My car has been acting strange lately.
When the car hits over drive @ 40 or so mph everything is fine. Smooth shifting and all.
If the car slow down to say below 40 and I give it some light throttle the engine will chug and chug bad.
Some times from a light and I give it gas quickly off the line to get through a light it hesitates.
Also if I accelerate from a 30 mph roll it will miss and sputter and then clear it self.
Now I disconnected the TPS and it was quite a bit better the chugging was hardly noticeable.
IF it is the TPS causing this grief why has the SES light not come on ?
Any Ideas.
I have cleaned the T/B, cleaned the MAF,plugs I have not checked but I' m sure they are good the idles fine and is smooth.
Fuel filter is new last summer,Injectors have been cleaned last summer,air filter is clean what else don't know.
Fuel pressure ???? can GM scan or test that????
If worse come to worse Im going to take to a GM dealer and have a tech come with me and scan while I drive.
Thanks
Old Sep 20, 2008 | 12:24 AM
99SSragtop's Avatar
Problem fixed.
New plugs.
5 plugs had cracks on the porcelain.
