Idle and surge issue
Old Sep 17, 2008 | 09:45 PM
stingr's Avatar
Default Idle and surge issue
I've just added a blower, intercooler,lt headers,ory,3 inch exhaust 44lb injectors and 270gph pump. I went to a speed density tune. The car ran fine on the stock injectors. When i went to the bigger injectors the car will not idle properly(wil bounce 200-350rpm at idle) and at very little throttle it will surge. the car has started to be tuned by hptuners. Anybody got any suggestions on what to change to make this idle and run right.
Old Sep 18, 2008 | 05:29 AM
BLK02WS6's Avatar
Did you scale the injector tables for the new injectors before starting it? If not, it is extremely rich and you should not run it until you get it scaled for the new injectors... and it needs a complete tune from the sounds of it...
Old Sep 18, 2008 | 08:48 AM
stingr's Avatar
Yah that was done. When its starts to bounce the wideband will jump from 16 to 11.1. when the throttle position motor gets unplugged the rpm will rise a bit but it will hold steady at 900-1000 rpm. I'm not sure thats means anything though.
