question about boost/MAP/aeroforce
Old Sep 20, 2008 | 10:19 PM
TRBOTYZ's Avatar
Default question about boost/MAP/aeroforce
I have been doing some searching to see what gauges to get for my car. During my searching I saw a lot of people with(or recommending) the aeroforce scan gauge and a boost gauge. If the aeroforce gauge reads MAP(isn't that boost?), would I still need a boost gauge or am I wrong about the MAP?
Old Oct 17, 2008 | 12:08 AM
96silverram's Avatar
It can be used as a boost gauge by selecting the proper item in the setup menu. I have this on a 96 LT1 car and it works about the same on a LS1.
Old Nov 1, 2008 | 09:38 PM
TRBOTYZ's Avatar
Thanks for your response. This is what the guy from the Aeroforce forum told me (mod/works there):
"You will need to add our 2 or 3 bar MAP sensor kit to read positive boost. You'll be connecting it to one for the gauge's analog inputs. You'll enter a conversion using a menu function in the gauge, and select "Boost" as your description to be displayed on the screen.
Your stock MAP is only a 1 bar and will only read vacuum. There is a parameter called "Boost inHg/psi" that converts the MAP value to inHg of vacuum, and psi positive pressure if you have a stock 2 or 3 bar MAP.
Todd"
Old Jun 17, 2011 | 07:44 AM
ramairetransam's Avatar
bringing an old one back , sucks we have to add a sensor to read boost in my procharged car , has anyone added the senror and what kind of pain in the *** is it .
