Adding Fan control 411 PCM
Old Sep 21, 2008 | 10:19 AM
poconojoe's Avatar
Default Adding Fan control 411 PCM
Is it possiable to add electric fan control to a 411 PCM using a truck cal file? I'd used the F-body code, but I don't know how to incorperate the truck shift position switch in to it. The F-body uses a totally differant set up in the floor shifter and the trucks have it mounted on the shift shaft on the case. I already wired it up using a truck harness and added the wires to the correct pins on the PCM, but when I was double checking the differances between the truck and F-body wiring I noticed that the shifter switch issue. Has anybody come across this and found a work around? Its a swap in to a 96 S10. I know i'm getting real greedy here, but i'd really like to control both fan outputs.
