Using an LS7/LS3 MAF Sensor with an LS2
Old Oct 5, 2008 | 01:52 AM
shovelhead73's Avatar
Default Using an LS7/LS3 MAF Sensor with an LS2
What's required to use an LS7/LS3 style MAF sensor with an LS2. Can you use the LS2 MAF table? If not is the LS7/LS3 table available? Does anyone know what the harness connector part number is for the LS7/LS3 Sensor?
Old Jan 10, 2011 | 06:43 AM
cowboyup's Avatar
I konw this is old. but I would also like to know..
Anyone?
I plan on doing the same or just go SD...
Old Jan 10, 2011 | 07:01 AM
moehorsepower's Avatar
I don't know about the electrical hook ups, but you will need a "Dump File" of the MAF Frequencies if it is drastically different..
