Torque Converter Tuning help/write up additions...
I have a TCI 3200 for an A4. Need to know what tables to update. I am currently boucing off the rev limiter on the 2-3 shift. Let me know what you need from me...'99 stock tune.
Back to reading...
when you log, take notice of the change in rpm/mph during wot.
since there's more slip, you'll be at a higher rpm. your shift tables reference rpm and mph, so what is happening is you're hitting the rpm, but not the mph to command the shift.
lowering the mph for the wot shift should do it. i usually edit the full throttle shift speed as well as the 90 and 100 values on the part throttle shift speed.
your lockup settings will be in the auto tcc section of the transmission section - apply/release speed - normal.
since your converter is a 9.5 inch unit out of a 4 cylinder car with a tiny lockup clutch, its probably a good idea to really cut back on the lockup. like under 25% throttle.
p.s. don't hold your breath over at the hptuners forum, cantalope kid. i don't think hptuners has enough resources to answer all our questions.
