Misfiring bad and throwing codes.
Old Oct 10, 2008 | 04:12 PM
R1ch's Avatar
Default Misfiring bad and throwing codes.
Last night I got stuck driving in a bad rain storm and on the way home my car started chugging and misfiring and the SES light started blinking.
I had the codes run today and it showed Multiple Misfires, Fuel Air Metering (?), and P0174 on bank 2.
Would this mean the O2 on the passenger side got wet and burned out or something from the water?
Old Oct 13, 2008 | 11:52 AM
ZL1Killa's Avatar
do you have exhaust leaks? how is your intake setup? did you get water anywhere? can you reset the codes and drive it and see what happens?
Old Oct 13, 2008 | 12:07 PM
sixpack_2_go's Avatar
check all your plug wires to make sure no water got in the boots. check your mass air flow sensor, make sure it isn'r wet.
Old Oct 14, 2008 | 11:33 AM
R1ch's Avatar
Got the codes run and turns out the O2 on bank 2 got wet or something and shorted out. I replaced it and everything's fine now.
