Trans Am Headlight problems
I have a 2002 Trans Am. The headlights worked fine yesterday, all four beams. This morning, the low beams don't work. Turn on the switch and the doors open fine, but no lights. Hit the dimmer switch and the high beams come on fine. Hit it again and darkness. What are the chances that both bulbs went out at once? If it's not the bulbs, could it be the dimmer switch? Is that built into the stalk around the column or is it separate somewhere? What else should I check?
Thanks for your help.
highly unlikely but possible, lol
