looking for speedo gears
Old Apr 3, 2009 | 08:31 AM
1966goat's Avatar
Default looking for speedo gears
I have a 700R4 trans in my camaro. It has 4.10 gears in the rear and need to change the speedo gear in the trans. Any help is appreciated. Thanks
Old Apr 4, 2009 | 07:27 AM
Weezzer's Avatar
Then you need to go to the right to the sponsor list >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
and buy a Diablosport programmer.
Old Apr 4, 2009 | 09:22 AM
johnson73801's Avatar
if its actually a mechanical speedo any tranny shop could get you what you need.if its electronic you can get a in line conversion box that modifies the signal for what you have. i didnt see what year your vehicle was but if its old enough to have a 700r4 i dont believe a plug in reflash type programmer will work. the older pcm were mot programmable thru th data connector
Old Apr 6, 2009 | 11:38 AM
Roger Mabry's Avatar
Default How to get the correct speedo gears
You know the rear end ratio so you only need the tire size:
http://www.bowtieoverdrives.com/cata....php?ITEMID=19
Old Apr 7, 2009 | 02:28 PM
JohnnyBs98WS6Rag's Avatar
What year Camaro?
When I swapped rear gears in my '68 Cutlass w/ a 2-sp Jetaway (Powerglide), I got new gears and a ratio adapter from here:
http://www.transmissioncenter.net/sp...n_______va.htm
