lookin for insight!!!
ok just trying to get some others insight on this set up.
ls1 with forged internals,ported l92 heads valve job, comp cam with 115 lobe seperation, ls6 intake. forced induction pushing between 7 to 10 psi of boost.
and i know ill need to beef up the trans and and gears.
and suggestions will be taking in.
From: Central Indiana Honors: 4th grade spelling bee contestant
Try looking through the following forums:
Forced Induction
Automatic Transmission or Manual Transmission (depending on what you have or want)
Gears & Axles
Thanks for joining the site! Keep in mind that the search function can help you with a lot of your questions as well.
Forced Induction
Gears & Axles
