engine knocking... replacement ideas??
Old Apr 10, 2011 | 03:03 PM
01LS1WS6's Avatar
Default engine knocking... replacement ideas??
Well it finally happened... engine started knocking yesterday evening. It has 130,xxx on it so i suppose its about time. I'm not quite sure what i want to do right now. I jacked the car up today and its definitely coming from the bottom of the engine. It also makes a strange howling noise from the exhaust. I'm guessing its a spun bearing. What are my options for replacement? Any ideas, websites, or any other info would be greatly appreciated..
Old Apr 13, 2011 | 11:03 AM
01FASTWS6's Avatar
5.3 or 6.0 swap. And you're on the best web page for all the info you need!
Old Apr 13, 2011 | 12:09 PM
RacingTiger03's Avatar
LS2! .. or if you're on a budget scour the for sale for awhile and find a used ls1 short block
Old Apr 13, 2011 | 05:52 PM
Paul Bell's Avatar
That's MISTER MODERATOR
MOST LS2 engines will have the 58x crank reluctur as it is a Gen IV engine.
HOWEVER, 2006 GTO and Trailblazer SS LS2 engines have the LS1 friendly 24x reluctor.
Going to this early LS2 engine is the easiest way to get a 6.0 liter engine in these cars.
Have a look here:
https://ls1tech.com/forums/5705127-post13.html
Old Apr 13, 2011 | 11:48 PM
ls1_bandit's Avatar
just to blow this out of proportion, lol, get an ls7 stroker and bore it out to a 454. only cost you around 20k. lol
Old Apr 14, 2011 | 04:12 PM
01LS1WS6's Avatar
I was thinking of getting an ls6 long block for 3600$
Old Apr 14, 2011 | 06:51 PM
ls1_bandit's Avatar
^^ that sounds pretty reasonable
