Firehawk Fluid Help
Old Sep 30, 2011 | 10:16 PM
Vortec HD's Avatar
Default Firehawk Fluid Help
I just purchased a 00 Firehawk. It did not come with a owners maunal. Can someone tell me or have a list of certified fluids to use from gear oil, tranny, cluch, brake fluids.
Thanks guys
Old Oct 1, 2011 | 12:33 AM
sjsingle1's Avatar
certified?
Old Oct 1, 2011 | 12:36 AM
99bluehawk's Avatar
Walmart engine, oil thats what I use. Do your regular changes and you will be fine.
Old Oct 1, 2011 | 02:57 AM
myk's Avatar
myk
Thanks guys
Just go to your local parts store and let them know what you got-they'll point you in the right direction. Then it's just a matter of you deciding how much you want to spend on the tier of fluids-synthetic vs. regular oil, etc...
Old Oct 1, 2011 | 08:20 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Here's the 2000 Firebird owners manual:
http://shbox.com/pdf/2000firebird.pdf
Off the shelf oils: Valvoline, Pennzoil, Mobil One. Syntetics are good here.
Off the shelf oil filters: Mobil One extended, K&N, Wix/Carquest, Hastings.
Stay away from cheep or store brand oils and Fram, Champion, Pennzoil, STP and store brand oil filters.
Rear end fluid: Synthetics can cause more issues than they help and are not needed for the low temperatures and pressures seen in gears. Reach for Lucas non-synthetic.
Brake fluid, Castrol LM.
Good luck with the car! Any pics for us?
