Help!
Now a little info on the car. It has 145xxx miles, was hit on the front left corner 2 years ago and sat till i bought it. I put new gas in started it up and drove it home battery was shot also but i charged it and it has been working fine. Also my oil pressure switch broke at some point so my gauge reads 0. I have done a fresh oil change and seafoam threw the tank. Want to do the fuel filter but it bent the hose a little and i got scared of breaking it lol.
I dont need this running right away is was a cheap purchase so far i have a total of 550 into it.
Yes, check all the connections at the battery and starter as well s at the alternator. Also, there's a few ground connections you should check.
If the battery is bad, it may not take a charge. It may also take a charge but not hold it.
