No cold air
Compressor wasn't coming on so I thought it was the relay as there was power in the port, new relay, compressor came on cold air. Tested it, 55 degress, water draining out. Next time I went out, a week later no cold air, compressor not on. Then it came on, no cold air. Checked the Freon, added some, still the compressor didn't come on, over charged, let some out. Right now the compressor is coming on, still no cold air. The compressor has always been noisy. I had her for 7 years, and I only added Freon when got her. Looks like the original accumulator, its not cold nor are the lines. But I never saw a compressor working and not making cold air. Any ideas?
after adding freeon it worked for a week only? usually that's a large leak condition if after adding freeon it doesn't blow cold for under two weeks. at that point components may need to be replaced (if that's the problem) Do you still see the compressor clutch spinning? How long was it overcharged?
