need help finding fuel lines
Old Oct 22, 2014 | 11:40 PM
sebe4848's Avatar
Default need help finding fuel lines
I am looking for braided, steel fuel lines for my 96 firebird ws6. Does anybody know where I can buy aeromotive or edelbrock lines? Thank you
Old Oct 23, 2014 | 12:31 AM
Paul Bell's Avatar
That's MISTER MODERATOR
You'd like these lines to go from where to where?
Old Oct 23, 2014 | 08:54 AM
sebe4848's Avatar
I am putting in an aeromotive 700 hp adustable fuel pump and an aeromotive fuel regulator rated for 30-70 ps1, I have also installed 35 lbs/hr fuel high impedance fuel injectors. I need to replace the entire stock fuel lines. So the new lines need to go from the pump to the where the stock lines hook up. I haven't yet measured exactly how much I will need yet.
Old Oct 23, 2014 | 09:11 AM
Paul Bell's Avatar
I suggest you run AN style hose and fittings. The braided covered hose is heavy and will wear against anything it rubs against. The cloth covered hose may get chaffed if it rubs against stuff so use it so sleeve the run in convoluted split-loom wiring tubing.
The AN hose & fittings companies make snap-on adapters for OEM fuel lines that you can use at the fuel rail end.
Old Oct 23, 2014 | 01:06 PM
Nasty N8's Avatar
We can help set you up with whatever you need. Have complete kits on the site as well. Everything tank forward. http://www.nastyperformance.com/shop/
Old Oct 25, 2014 | 11:55 PM
xGnarciax's Avatar
Sorry to thread jack but would there be any benefit in running braided lines from just the pump module to the hard lines? And if so is there a kit out there that has all the lines already cut to lenght? TIA
