is this to much for the weekend warrior?
Old Apr 28, 2015 | 03:42 PM
bleepster's Avatar
Default is this to much for the weekend warrior?
been looking at installing new front and rear sway bars and a panhard bar and LCA bars on my 2002 Firebird V6 (BMR brand)
its just a weekend cruising type car. once in a while when taking sweeping curves, and hitting bumps, it feels like the rear end wants to "hop" - its hard to explain. I have the posi rearend if that makes a difference.
what benefits would I notice if I were to install new? or should I not waste my money?
appreciate your advice - thanks
Old Apr 29, 2015 | 02:15 AM
ChristopherWelkin's Avatar
Can't comment on the panhard and LCA's, but when I got new swaybars and ditched the ones that came stock with the V6, the car felt different on a whole new level. The car doesn't feel like a van when you're turning on corners anymore.
Those and shocks were the best investment I've made on the car so far, and they're honestly not that pricey
Old Apr 29, 2015 | 06:48 AM
bleepster's Avatar
sounds good. thanks for the tips. i just replaced rear shocks and axel bump stops. will do fronts later along with new sway bars.
Old Apr 29, 2015 | 06:56 AM
01 Vert ws6's Avatar
Shocks and struts will make a difference
Old Apr 29, 2015 | 12:42 PM
Daniel Richards's Avatar
on mine I just went up to the WS6/SS stock bars 32/19 with poly bushings. I don't know if I would suggest any bigger then that for sway bars on the v6, especially if you lower it.
replace the rear control arms, because they likely need new bushings, but I would only suggest replacing the panhard (and only with an adjustable one) if you plan to lower the car.
save the money on the Brand Name sway bars and put it into the shocks and springs, you'de be amazed just how much the 32/19 (stock WS6/SS bars) change the ride by themselves.
Old May 14, 2015 | 11:15 AM
99Brd's Avatar
Replaced the front and rear away bars on mine along with lower control arms, made all the difference in the world. No more body roll. I also added the UMI relocation brackets to the rear for extra support.
Old May 14, 2015 | 02:56 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
That combination of parts would definitely be a good stating point. I would recommend shocks and springs as the next step after these mods. Give me a call and I can put you together a package on these parts and see if I can save you a little money on it
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old May 15, 2015 | 12:19 AM
myk's Avatar
myk
What shocks did you go with? In my experience shocks and sways are the best improvements you can make to any car, and return the greatest amount of performance per dollar...
Old May 15, 2015 | 06:37 AM
bleepster's Avatar
ended up getting some Bilstiens for cheap for the back. will do the same for the front. prolly another "winter" project
Old May 20, 2015 | 01:10 PM
ahritchie's Avatar
A "hopping" rear end by hitting a mid corner bump is just because these cars have a solid rear axle....it will still "hop" on a mid corner bump if you put a full aftermarket suspension in it...just not as badly. Every solid rear axle car has this issue which is why it's now obsolete technology; the 2014 Mustang was the last car to offer one. I don't think a V6 makes enough power to be flexing the stock control arms/panhard bar like a modded V8 does....I would stick with just springs/shocks/swaybars IMO.
