99 trans am performance
Hey guys, I have a 99 ws9 trans am with the 5.7 liter engine and a 6 speed trans, recently I've noticed from take off if I punch the throttle my engine will start to bog out at higher rpm's in 1st,2nd or 3rd gear.I took it to gm and they changed the fuel pump and told me it could be the o2 sensors or the throttle body, so they cleaned the throttle body and I've changed both front o2 sensors that they said could be at fault and the car still seems to fall on its face at the higher rpm's, any ideas, thanks
2 codes came up, they were P0137 and P0157, here is what they said:check lack of pwr/ses-road test on parkway/ lack of pwr on hard accel,fuel trims high & 02 sensors drop to near 0mv. Also noticed maf sensor only reached 50gps.Clean maf sensor, also noticed pcv not secure (possibly causing vacuum leak on accel) road test maf reached 80+gps now, fuel pressure ok now
started just after I bought it I thought it was bad gas cause I filled it up with just regular unleaded, but then found out it was weak fuel pump, haven't tried putting in old plugs then taking it for a drive, you all know what a pain it is to change plugs
You will need to get a special MAF cleaner from the parts store to clean the thing. (Air won't work.) The MAF has a heating circuit on it, which burns off contaminates, but the oil from the filter is just too much. The stuff will be crusty and caked on. (You can see it with a good magnifying glass as black crud.)
Electrical contact cleaner will also work, but the MAF cleaner is supposed to be safer for the plastic pieces of the sensor.
Thanks for the input would not have thought k&n oil would do that.Will have to look at the MAP sensor when I get home friday night, if that's the case will be getting rid of the filter for sure, and getting some of the cleaner for sure
I had to deal with this the hard way. (After shelling out money to help find the problem.) GM issued a bulletin on it many moons ago and K&N has responded with an extensive propaganda program: http://www.knfilters.com/MAF/massair.htm
I think the posts and experience on this site have shown definitively that the problem is real and K&N's tests don't hold for the conditions on our cars.
