Delphi V7 a/c compressor
Old Oct 3, 2015 | 08:17 PM
johnfin's Avatar
Default Delphi V7 a/c compressor
Has anyone worked on their compressor clutch. i replaced the bearing and i cant get the gap on the place correct. its about .090 and its needs to be .015. the bearing replacement has no effect on the problem because the snap ring has to align so the pulley is not the problem, its the spring plate not going far enough down, i used the installation tool with the bearing and nut. any thoughts on where i am screwing up?
