New ls1
Actually, when I turn my left blinker on. The green arrow stays solid. And neither front or rear lights flash. I read that it could be the socket for the front. And the rear might just be out. Any ideas?
Welcome to LS1tech!
Have a look through the stickies in this section for the better way to repair those pesky turn signal sockets.
Can you post some pics of this engine?
Oil: Any synthetic with lower viscosity should do you well. I use the 0W-40 Castrol that says "made in Germany" on the back, found at Walmart for about 25 bucks for a five quart jug. Use a quality oil filter like a Wix, K&N, Hastings or Mobil1. Never a Fram or store branded filter.
A usual and easy bolt on upgrade is installing a LS6 intake manifold. RETAIN the four corner cooling tubes under the intake. The LS6 intake's underside's ribs need to be shaved a bit to clear the tubes.
Beyond that, many of our fine sponsors such as Texas Speed could set you up with a head & cam package. Remember a new timing chain, oil pump, headers....the list goes on.
Most likely your blinker problem isn't a bulb or wiring issue. There are a couple screws holding your lower dash on directly below your steering wheel. Take that off. And fit a flashlight under there and get sight of a silver tin cylinder located just to the right of lower dash. Kind of behind the cigarette lighter. Unplug it and get a new one. Its called a flasher and will quit blinking when it goes bad. It controls the blinking of hazard and blinker lights. I already replaced mine once. Cheap fix.
