02 WS6 Transmission Help! So I drained the transmission pan and changed the transmission filter and ensured the seal was in place in the tranny where the filter goes in. I read it takes about 5 to 6 quarts to refill.......well that isn't the case here! After about 2 quarts of filling through the trans dip stick, oil came out. I thought maybe it takes time for the oil to make its way to the pan so I left and returned about 30 minutes later. Came back and added another quart of oil. Started the car for about 5 minutes and quickly cycled through the all the gears since it was on stands. Shut the car off and when I pulled the transmission dip stick oil shot out! Never had this happen before so I'm at a loss for the day. What would cause this?? I will continue with this in the morning. Any help welcome! |
I figured out the problem, thanks for the help anyways. |
Originally Posted by luilui
(Post 19145255)
Originally Posted by Jaxem
(Post 19145304)
You should enlighten everyone who came and read your post but didn't know how to help as to what the problem was... |
© 2024 MH Sub I, LLC dba Internet Brands
