Taillight problems
So, your regular lights and your turn signals have the problem.
shbox posts the schematics for your car: http://shbox.com/1/exterior_lights.htm If you click through the links, you'll see that the power source for both the regular lights and the turn signals is different... but you have a common problem.
I would think the most likely issue you have is a grounding issue for all the bulbs on that side.
If it is not the bulbs, how about the sockets? Are any sockets badly corroded? I have had to splice in two new light bulb sockets thus far!
If this is not the case, maybe your tail light reflector is peeling away? This is what is happening on my tail lights, although I am not sure how dim they are compared to when they were new.
With regards to your turn signal blinking issues, I would check those bulbs out and the sockets! When I had a bad driver side turn signal socket, my indicator light would stay solid when the signal switch was engaged.
If it is not this, it could be a bad turn signal switch, and maybe a bad relay. These are some of the problems I have come across with my car.
