2000 Formula Firebird
Old Dec 8, 2018 | 03:23 PM
thunderchickentoo's Avatar
Default Hello
New here, just saying hello I am located in Elkton Fl 2000 Formula Firebird Does any one know what the WS-9 option included
Old Dec 9, 2018 | 07:56 AM
wssix99's Avatar
Save the manuals!
Welcome to the site!
The WS9 option is the conversion of the vehicle to the Formula model. There are lots of sites where you can look up these RPO codes and they will list that one, also. Everyone with a Formula should have a WS9 on the door sticker.
Old Dec 10, 2018 | 09:56 AM
Default 2000 Formula Firebird
Have read a lot about options. I am searching for info on our Formula Firebird. It is a WS-9 0ption package. So far i know it has fiberglass doors,front fenders and what appears to be a standard Firebird steel hood. Any help in figuring how they optioned this car new is greatly appreciated. Thanks, Jonathan
Old Dec 10, 2018 | 02:20 PM
two lane blacktop's Avatar
The Service Parts Indentification label located on the drivers side door will provide all the information that you are seeking...WS-9 .....Only indicates it is a V8 car...Trans Am or Formula....All the alpha numeric codes on the label will tell you everything from the kind of seats to wheel and tire combos to the sound system and everything in between....
Old Dec 10, 2018 | 02:27 PM
WhiteBird00's Avatar
Ungrounded Moderator
WS-9 means "Formula" - saying it is a Formula and a WS-9 is redundant because they mean the same thing. WS-9 technically indicates a V8 Firebird because even the Trans Am will have the WS-9 code but will also have the Y82 (Trans Am) code. So a WS-9 with Y82 is a Trans Am while a WS-9 without the Y82 is a Formula.
The body panel materials (BTW, the fenders are plastic not fiberglass) are the same across all models except for hoods... the flat hoods are metal while the ram air hoods (WS-6 and SS) are composite. These were not option choices (again with the exception of the hood).
There is an option code label on the left door jamb. It lists a bunch of three character codes indicating the options on your vehicle. There's a list of most of them here: https://ls1tech.com/forums/1740895-post17.html
Old Dec 10, 2018 | 02:50 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
This is correct. But, to complete the information above, there is also a Formula specific code - W66. So a Formula would have WS9 and W66, while a Trans Am would have WS9 and Y82.
Old Dec 10, 2018 | 03:03 PM
Default Thanks
Info invaluable, more you guys help me the more questions i have. Thanks so much. So read the article about the 2001 upgrade Formula birds ours was manufactured 4/00 with cast iron eexhaust manifolds, shorty converters and no EGR System. Does it have more hp?
Old Dec 10, 2018 | 03:46 PM
RPM WS6's Avatar
If yours was manufactured in April of 2000, then you definitely have a 2000 car, not an '01. So the '01 changes and upgrades don't apply to your example. Also, your 2000 car would have originally come with EGR. The 2000 cars did receive an exhaust manifold update to cast iron pieces, but the EGR boss was still utilized on this model year. The same exhaust manifolds were used for 2001+, but the EGR provision was left blank and untapped.
If EGR has been deleted from yours, then it has been modified. So it may or may not have more horsepower than stock depending on what other modifications may have been done.
FWIW, various factory ratings notwithstanding, all LS1 engines make about 345-350hp stock, same as the C5. The engine differences in various model years don't account for more than a ~5-10hp difference at most. Some models (SS, Firehawk) were available with optional (or standard in the case of Firehawk) items (dual/dual exhaust, Blackwing lid), depending on year, that would boost horsepower by a small amount more. But these items are bolt-ons which could be added to any LS1 F-body and would be worth the same gains (no actual engine difference for those higher trim levels).
