RPO Code search...
Old Jun 18, 2020 | 10:46 PM
Ballistic17's Avatar
Default RPO Code search...
I have a 95 Formula with the M6. I am wanting to find out all the other build options but can't find the RPO codes anywhere on the car. I check the normal spots, door, glove box and no tag. Is there a way to get the codes with the vin? Any help would be great. Thanks.
Old Jun 19, 2020 | 12:46 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The SPID sticker was originally located on the driver's door in the jamb area. Sounds like yours has been removed or has fallen off over the years.
You can usually get the codes through any GM dealer via their VIS system, and/or through websites like Compnine, but for stuff older than 1996 some sources are a bit more hit-or-miss.
