Steering Controls help please
The hard part, and potentially dangerous part, is pulling the air bag. If you aren't experienced with that, you should definitely disconnect the car battery first and be sure to keep it at arms length at all times.
If you want to try a hail mary before buying new switches... Open the switch assembly. Inside, you will see the circuit board and should be able to find the one switch that is bad or stuck. This thread has some pictures: (You can also see the wire connectors on the back of the circuit board where you would disconnect the switches.) https://ls1tech.com/forums/appearanc...rols-pics.html
Once inside, if your switches are just gummed up, you may be able to get them working by using spray MAF cleaner on them. (I would be sure to use MAF cleaner as it is safe for plastics.) If you do this be sure to do it in a ventilated space and have a fire extinguisher nearby just in case!
