Consistent Overheating problems after replacing everything
Old Jul 7, 2023 | 02:41 PM
bigbird349's Avatar
Default Consistent Overheating problems after replacing everything
Hi my 96 lt1 firebird has still been having overheating issues and has been dripping coolant from the passenger side after replacing the water pump, intake manifold gasket, thermostat, and bleeding the coolant several times. I don't see any blockages in the radiator and I'm not sure where to go from here. Any help would be greatly appreciated!!
Old Jul 7, 2023 | 05:30 PM
01CamaroSSTx's Avatar
Have you checked the freeze plugs?
Old Jul 8, 2023 | 09:03 AM
Y2K-WS.6's Avatar
Take a look at the steam line at the rear of the engine. They can go bad with age and corrosion.
Old Jul 8, 2023 | 12:50 PM
slothman's Avatar
compression test. and leak down test. could be the head gasket.
Old Jul 9, 2023 | 11:18 AM
Wraith99's Avatar
Yup, all of those suggestions. Start with what you think is easiest.
