Idles Bad
Old Nov 27, 2004 | 11:07 AM
chewie7968's Avatar
Question Idles Bad
When I Start My Car It Idles Fine.after Warm Up It Starts To Idle Around 500 Rpm + Or - And Sometimes It Will Idle Fine Again. Goes Down The Road Fine.no Back Fires No Nothing Just At Idle And Light Take Off.moderate Take Off It Will Pull Then Lose Power Then Go Fine. Thats Only Leaving A Light Normal Driving And Again Not All The Time Sometimes Its Fine.any Ideas On What Is Causing Problem??
Old Nov 27, 2004 | 11:23 AM
racer88's Avatar
I had a bad plug wire make mine stumble and backfire. I changed plugs and wires problem went away.
Might wanna change plugs depending upon how old they are.
Old Nov 27, 2004 | 01:02 PM
chewie7968's Avatar
I PUT IN BOSH PLAT 4. WHAT BRAND OF WIRES DO YOU SUGGEST
Old Nov 27, 2004 | 02:23 PM
LT1Burnout's Avatar
check out www.thunderracing.com, they've got good stuff for wires and plugs.
it could b lots of things, i had the same problem. first it was a plugged MAP sensor, then it was my alternator going bad fluctuating my idle.
Old Nov 27, 2004 | 02:41 PM
racer88's Avatar
I bought Taylor Thundervolts from Racenet they were $71.45 shipped vs $89.95 before shipping at Thunder racing btw for the same wires.
Old Nov 27, 2004 | 02:48 PM
LT1Burnout's Avatar
not bad.. good deal.
Old Nov 27, 2004 | 03:15 PM
racer88's Avatar
I shop around, but when it comes to higher priced mods like my 12 bolt I got mine thru Thunder and just bought my Man a new badass cam for Xmas
Old Nov 27, 2004 | 03:29 PM
LT1Burnout's Avatar
sheesh, and all my girl will probably get me is a new cell and plan so she can continue to nag my ear off.
Old Nov 27, 2004 | 04:41 PM
racer88's Avatar
Yeah well, we both have the same cars and interest with them and we race ours. He does all of my work on mine, so it's okay he's supposed to be faster than me I'll help to keep him there.
Old Nov 27, 2004 | 04:50 PM
LT1Burnout's Avatar
wow, my girlfriend can definitely learn alot from u.
Old Dec 3, 2004 | 07:40 PM
chewie7968's Avatar
Thanks For All The Advice. What If That Isnt The Problem,what Else Could It Be??
Old Dec 3, 2004 | 08:54 PM
LT1Burnout's Avatar
assuming you have an LS1 with OBDII, i would invest in an autotap. if you have lots of miles on her i would at least just pop the MAP sensor and clean it out. also, maybe try tapping on the MAF sensor (gently) or jiggle the connector while the engines running at idle. any fluctuation is usually a sign of a faulty MAF.
Old Dec 23, 2004 | 04:27 PM
chewie7968's Avatar
Ill Try That.thanks.WHATS AUTO TAP??
Old May 3, 2005 | 09:12 PM
chewie7968's Avatar
Thumbs up
I Found It!!!!!!!!! I Do Feel Like An Idiot Though. It Was A Vacume Leak Behind The Throttle Body,a Little Tape And Runs Like A Bat Out Of Hell
