Headlight Noise
Old Feb 22, 2005 | 10:05 AM
98LSVETTE's Avatar
Default Headlight Noise
Need help with my headlights. The problem is when I turn off my headlights there is a loud banging noise from the driver side headlight goes down, but there is no noise on the way up. It doesn't appear as if the headlight is physically hitting anything. My car is a 2002 ws6. thanks
Old Feb 22, 2005 | 10:33 AM
billybob's Avatar
sounds like you have a striped gear. you can flip it over 180 degrees and get more life out of it or get brass gears to end the problem all together.
Old Feb 22, 2005 | 11:27 AM
98LSVETTE's Avatar
Thumbs up
Thanks I will check that out
Old Feb 27, 2005 | 07:48 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
My '00 has done that since I picked it up new in December '99. Nothing has broken or stopped working yet. If you can't find a stripped gear, then it's probably nothing to worry about.
Old Feb 27, 2005 | 08:42 PM
VIP1's Avatar
Copy & Paste Moderator
There is a stickie at the top of this section:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
