New Car Problem
So I went, and the car is heavily modified. It's got a borla exhaust with corsa premium tips, bbk headers, ls1 intake manifold, new yokohoma tires, ls1 edit programming, k&n air filter, and a few other mods. I like the car cause it has all the aftermarket products ill need, but I have a PRETTY BIG problem.
I turned the car on, gave it like 1-2 minutes popped the hood. Then I noticed smoke, white smoke, coming from the conveyor belts of the engine. I'm thinking it might be rain/ condensation because it had rained the night before and it was still damp out. It eventually stopped after 3 minutes
Then I took it round the block, and at 5000 rpms and 2nd gear, I could smell it smoking again. It also stopped after a minute once i shifted and lowered the rpms. But I wasnt really near redline???? i think 6500 is redline.
But on normal driving, the car runs fine. no smoke no problems, but I dunno whether the problem is that the engine is broken. I'm having a mechanic look at it, but I REALLY NEED Feedback as to what is wrong???
What's ur guess? Is it just rain and bad driving or is the car damaged? The guy bought an SRT-4 as his trade in car, so he obvious knows what hes doing. He changed the tires, which could mean he dogged the car and needed to change em... who knows? ANY FEEDBACK ASAP = MUCH THX
Heavy 'billowing' white smoke can indicate a problem with the cylinder heads, water/coolant getting into the oil, generally bad news. I would think it would probably be smoking all the time if this were the case, but not sure.
A little white smoke at startup is usually just from condensation in the exhaust system, doesn't apply here though.
What is your state? Surely there's more than one used 2002 (or 2001s are very similar) WS6 TA available, just take some looking around... if you're unsure about the condition of the car, it'd probably be better to find a different car than to gamble on this'n, could have additional problems show up later down the line.
