Hose Help
Old May 7, 2005 | 11:15 AM
chewie7968's Avatar
Default Hose Help
CAN SOMEONE TELL ME WHERE I CAN FIND A DIAGRAM OF THE VACUME LINES ON MY 99 LS1 T A.I NEED TO FIND OUT THE PART I NEED.THE LINE COMES OFF THE INTAKE BEHIND THE THROTTLE BODY BELOW THE EGR LINE.CAN ANYONE HELP?
Old May 7, 2005 | 11:46 AM
ACW's Avatar
ACW
I can probably find what you're asking about, but haven't been able to figure it out from what you've said so far... could you be more specific about what this line is for and what it connects to?
Old May 7, 2005 | 11:52 AM
chewie7968's Avatar
IT CONNECTS BEHIND THE THROTTLE BODY THEN RUNS DOWN THE PASSENGER SIDE OF THE ENGINE BETWEEN THE VALVE COVER AND INTAKE.IT HAS A LEAK THAT CAUSES ROUGH IDLE + HESITATION AND CAUSES THE CAR TO DIE WHEN IT IDLES FOR 5-10 MINUTES.I HAVE TAPED IT UP FOR NOW BUT I NEED TO REPLACE IT ASAP.
Old May 7, 2005 | 12:39 PM
ACW's Avatar
ACW
Aha, sounds like this is it
Tube, PCV (From Right Side Rocker Arm Cover (Valve Cover) Connector To Throttle Body)
1999-2002 LS1 - part number 12556454
Can be ordered from GM parts dealers such as our sponsor SDPC: http://www.sdpc2000.com/search.asp?s...6454&doquery=1
Old May 7, 2005 | 01:09 PM
chewie7968's Avatar
I DONT SEE WHERE IT CONNECTS IT RUNS UNDER THE DASH TO THE FIREWALL ONTHE PASSENGER SIDE.ARE YOU SURE.IT IS A RUBBER HOSE.A DIAGRAM WOULD HELP ME.
Old May 7, 2005 | 01:28 PM
ACW's Avatar
ACW
I'm not completely sure, and unfortunately I haven't found any helpful diagrams or photos of that area. Hopefully someone else will come along with something more concrete to contribute
Old May 7, 2005 | 08:12 PM
Danny2tek's Avatar
sounds like the PCV to me
