78 interior help
Old Oct 13, 2005 | 08:21 PM
78transman's Avatar
Default 78 interior help
Hey, I'm new to the forum. I recently got a 78 that I am doing a complete restoration on, and I am working on stripping the interior at the moment. Any clue on how to take out the middle console so that I can finish tearing up the carpet?
Old Oct 14, 2005 | 11:55 AM
78400stud34's Avatar
hey man welcome to this thread.
if you havent already come check out www.transamcountry.com
there are almost 2000 users, and best of all its strictly deticated to the 2nd gen t/a. you got a question, they got 40 answers!
now for your question. To remove the consol:
Open the consol pocket lid unscrew the box (if you look on the bottom there are 2 screws)
if you have an automatic you need to take off the shift head to do this take off the button (screw driver) and there is a C clip on the post sticking up you need some pliers to open up this c clip and take it out and the head should fall off.
with that look under the dash / top of console and you will see 2 nuts mounting the console to the dash one on driver one on passenger lift the back of the consol up and pull out and you are good!
Old Oct 20, 2005 | 08:10 AM
jksz71's Avatar
He is right on both counts. Definetly check out tac and his instructions are correct. Proud to be a member there also
Old Oct 22, 2005 | 07:31 PM
JCS30TH's Avatar
Your restoring the car and can't figure out how to get the center console out? I think I could take apart and put back together a 2nd in my sleep. Lord knows I turned enough wrenches on them. I miss them all.
1977 T/A
1978 T/A 6.6
1979 T/A
1980 Turbo T/A
Old Oct 25, 2005 | 08:42 PM
ya thats one thing i really noticed in my expirence with this car. everything is one or two screws and very badly designed engineering (prolly good for the time).
and no to mention how you can stick your head all the way to the ground through the engine compartment!!
