95 bird
Greg
-Engine, obviously
-Transmission (and clutch assembly)- your 5 speed won't mate to an LS1
-Wiring/computer- you would need entirely new wiring harnesses and computer
-Brakes- most, if not all, 95 V6 cars had drum brakes in the rear. You would have to swap those for discs. Also the LS1 cars probably have bigger front brake discs than the 95 V6s
-Suspension- V8s have a beefier suspension
-Steering ratio- V8s have a higher steering ratio (less movement of the steering wheel required to make the car turn a certain amount)
-Gauge cluster- speedometer goes higher on V8s, LS1 cars also have digital odometer
-Fuel pump- V8s have larger fuel pumps
-Tires- V8s have wider tires, and you might want some bigger wheels as well
So, between the value of your car and how much you would have to spend in parts alone (not even counting labor), you'd end up spending more money probably than if you just sold your car and bought an LS1 car. Besides that, there is a chance that after you have done all that converting, you might have problems with something and have to go back and fine-tune it, or troubleshoot to find the problem. On top of that, an LS1 will have much better retail value than a converted V6 car would. Also, your insurance might not cover you if you get in an accident and they find your car has an LS1 instead of a V6.
I was in the same situation as you once, I had a 97 V6 Firebird and wanted a V8. After penciling it out over and over, it's just not worthwhile to do.
Greg
If expense and driving age is a contributing factor, then the V6 might not be a bad idea. Younger male drivers really pay the price when it comes to insurance. I've been there and done that
You'll save a little on insurance since it's not a V8 car, and unless you want to start racing right off the bat they're still fun cars. I had an '88 Camaro with a V6, and it was a really fun car. I swapped the wheels, hood, and exhaust and made it a fun car. I traded it with over 200,000 miles on the odometer.As far as a swap, there's just way too much to change out in order to go from a V6 to a V8 for a street car. If you were building a drag car, then picking up a lower-priced V6 car with a good body is the way to go. You'll be better off starting with a V8 car if that is what you want.
Scott
Greg
