not sure where to find this
Old Oct 2, 2006 | 09:00 AM
2000WS6TA's Avatar
Default not sure where to find this
google didnt help me. or yahoo, or search so though maybe someone might know where to go. im trying to find stock 0-60 and 1/4 mile times for a 1969 firebird w/ 400. im thinking about buying one and lightly modifying it and im just wondering where my starting point is going to be.
Old Oct 2, 2006 | 04:50 PM
LS1W66's Avatar
It depends on which of the 3 400's the Car has
Base 325 HP ...In GTO 350 HP
R/A III 335 HP... In GTO 366 HP
R/A IV 345 HP... In GTO 370 HP
Firebird and GTO engines are Identical except that the Firebirds had a small tab attached to the Carbs that limited the secondary throttle opening.
that is why they are rated at a lower Horsepower level. Most people ground the tab off.
Another factor is gearing, both Trans and Rear end
The average R/A III 4spd car with 3.55 or 3.90 gears would run anywhere between 14.5 to 14.1 at around 98-100 MPH
The difference between Base and Ram Air III engines is just a Cam And tuning. The R/A IV has better Heads Intake and camshaft, plus Forged internals. A well Tuned Ram Air IV can make an easy 425 HP.
Old Oct 2, 2006 | 07:01 PM
Captainofiron's Avatar
A good starting point would probably be some headers and depending on if you want getting rid of the Rodchester Q junk I mean Qjet. Maybe a Holley or a Demon, thats what I have.
Then maybe a cam, Most ponchos really like a single pattern cam, with that you should be putting down some awesome bottom end numbers and help out the top end power
