Subframe connectors
Old Oct 13, 2006 | 03:42 AM
The Butcher's Avatar
Default Subframe connectors
He all. Well, first snow of the year and we all know what that means! Anyways, i'm looking for a set of tubula, weld-on subframe connectors and have had little luck. I'm lookin for a second gen if it matters, but all I really need is some good names. I tried the search and either it isn't working or my car is the only one that didn't come stock with aftermarket connectors Thanks everyone!
Old Oct 13, 2006 | 05:58 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
They mention using Moroso subframe connectors in this article...
http://www.highperformancepontiac.co...tiac_trans_am/
Old Oct 13, 2006 | 08:19 AM
TRANSAM75's Avatar
Make Your Own. Its Just Strait Tubing,much Cheaper.
Old Oct 14, 2006 | 12:33 AM
Hey, thanks for the replies. Making your own sounds like a good idea..would they just basically connect the ends of the front frame? I'm not to fimiliar with where these things go exactly
Old Oct 14, 2006 | 01:13 AM
Philhawk02's Avatar
I'd be curious to hear how they work out for you after you get them on. I'd like to know if they make a big difference on the 2nd gen. I've been toying with the idea of adding them to my 2nd gen as I slowly restore it over the winter.
Old Oct 15, 2006 | 07:23 AM
EPP's Avatar
EPP
I think I have a set in stock for the 2nd gens. I'm only approx 20 minutes away from you. 260 244-4808 is our number, I can check on them for you tomorrow. Bob
Old Oct 15, 2006 | 07:16 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Global West makes a set of tubular connectors for your application. Most others (Comp. Engineering, Chassis Engineering, etc) use box style, which also works fine.
Derek
