BAD Stuttering problem! Help!
Old Oct 27, 2007 | 02:19 AM
MOWNED's Avatar
Default BAD Stuttering problem! Help!
Ok so I went and had my slp loudmouth 2 exhaust removed today to replace it with my new magnaflow exhaust.
Im driving home and it drove beautiful, nice and mellow sounding compared to the nasty raspy loudmouth I had with no cats.
Anyways I get home and decide to do a few other mods.
First I remove all the emissions b/s that was on my car from when they put 99 camaro exhaust manifolds on it before it was traded in.
I put the intake manifold plug in and put the 3 plates on the exhaust manifolds.
Then I remove the hoses coming from the air pump and disconnect the fuse so it wouldn't blow air.
I then added my new O2 sims and go for a drive.
Well all of a sudden it is really idling nasty (worse than normal with my MS3) then I go to give it gas and it falls on its face and doesnt go anywhere then all of a sudden jumps and goes.
Anyone know what this could be its been driving like this ever since!
I cleared all codes with my obd2 scanner and still nothing.
Old Oct 27, 2007 | 07:39 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Possible vacuum leak around the intake manifold plug.
Did you make sure to put the sims on the rear O2 sensors?
Old Oct 27, 2007 | 11:14 AM
MOWNED's Avatar
there's only 2 right? I saw the ones that are in my y pipe and put them there.
Old Oct 27, 2007 | 02:35 PM
MOWNED's Avatar
figured it out, I had the O2 simulators plugged into the front O2 sensor slots, so I plugged in the front O2 sensors and then plugged in the O2 sims in the rear spots where there wasn't any O2 sensors and boom runs great!
