Pontiac GTO 2004-2006 The Modern Goat
Speed inductions are ready to ship!
Old Apr 5, 2004 | 11:35 AM
tbyrne's Avatar
Default Speed inductions are ready to ship!
We have the new Speed induction in stock and ready to ship!
By Utilizing OEM grade composite materials, this system is less prone to heat-soak than comparable aluminum, or chrome steel pipes, resulting in cooler intake temperatures.
Includes:
4" High Flow Smooth Intake Pipe
Silicone Adapter Hoses
Lifetime 9" Cone Air Filter
This system will provide you with a 13-18 rear wheel horsepower increase by utilizing OEM grade composite materials that will be less prone to heat-soak than comparable aluminum, or chrome steel product. This allows for cooler intake temperatures and more horsepower to your rear wheels!
You can add a set of TBYRNE MAF ends to your order for only $85. -
The T BYRNE Motorsports MAF ends are a quick, easy install that will give your GTO a 6-8hp increase. Available in black, satin, blue and red finish, each set sports the T BYRNE Motorsports logo and has a teflon coating. Plus the unique internal venturi shape will help smooth the airflow into the motor. The internal form was designed much like the intake on a jet engine, for less turbulence and better flow plus the teflon coating will aid in reducing surface friction. Our MAF ends interlock for a better, smoother alignment of the air track.
Just mention this offer when you place your order.
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy
Old Apr 6, 2004 | 10:22 AM
1COOLPC's Avatar
Do you happen to know if the tube will fit in with the stock air box, not using the cone filter? I would like to replace the tube between my MAF and Throttle Body but keep the stock air box. Is it possible that you could check this as a possibility to fit? I will buy one today if so. Thanks.
Old Apr 6, 2004 | 01:48 PM
tbyrne's Avatar
We have a customer that ordered the tube by itself. He was going to cut it to fit with the stock airbox.
Old Apr 6, 2004 | 01:53 PM
1COOLPC's Avatar
Thank you. I would like to order the tube myself. What is the cost on just the tube and how do I order? I am a prior customer.
