Pontiac GTO 2004-2006 The Modern Goat
4L80 conversion
Old Oct 17, 2014 | 01:21 PM
dw456post's Avatar
Default 4L80 conversion
Did anyone that converted to a 4L80 get their speedo and cruise to work?
My issues:
I swapped from T56 to 4L80 and changed out the engine/trans wiring harness to a A4 harness. I have the PCMforless conversion plug and relays. They also supplied a T42 and put the A4 tune in my computer.
(1)Speedo is way fast, 40mph shows about 85mph. The VSS plug is plugged into the rear sensor.
(2) still have to depress he clutch switch to get it to start.
(3)No cruise control.
Thanks for any ideas!
dw
Old Oct 17, 2014 | 01:39 PM
AGearHead4Life's Avatar
My issues:
dw
That speedo and clutch issue should be able to be fixed with HPT.
Old Oct 17, 2014 | 03:17 PM
dw456post's Avatar
Thanks
Old Oct 21, 2014 | 09:19 PM
dw456post's Avatar
Got the speedo corrected with HP Tuners. Still need to fix the clutch switch and get cruise turned on. When I depress the cruise button, the dash shows cruise engaged. It does not hold the speed though. It does not turn off with the clutch switch or brake switch. It has to be turned off at the hand switch.
Old Apr 16, 2015 | 06:31 AM
MrBlueDevil14's Avatar
Now that you've had your 4l80e for some time how do you like it? My gto is currently getting a Jakes stage 4 installed at the moment
Old Apr 16, 2015 | 09:26 AM
dw456post's Avatar
Love it !
I got all of the little electrical problems solved. The company that I sent the computer to did not complete the auto tune. Had to send it back.
Old Apr 16, 2015 | 12:42 PM
I know that I love mine too. Mine is stock and I can beat the mess out of it and it wont die. When I had a 60e I was alwasy scared waiting for the it'd quit.
My '92 Camaro has a T56 that I'll probably eventually swap out for an 80e as well.
