Pontiac GTO 2004-2006 The Modern Goat
Done with Centerforce
Old Nov 1, 2025 | 11:41 AM
jamesgr81's Avatar
Default Done with Centerforce
This is the last time I will ever install a Centerforce clutch. After only a few thousand miles it is slipping badly. Just like the last one. Have the Tick pedal and slave. Shifts fine just can't handle the HP. I have had good luck on the SBC applications but on these LS engines they are junk. What's the best clutch you guys have found?
Old Nov 2, 2025 | 04:47 PM
2QWK4RU 06 GOAT's Avatar
Clutch can be a mixed bag. The tick master kit caused numerous clutch failures back in the day and had other issues as well. You might go back to stock and check the slave spacing to get back to normal. There was no real clutch master solution back in the day except for the one I use to make back in the day.
I've had some good luck with ACT more recently. I used mcleod lots, but then had 2 back to back fails and abandoned them, too. I hear they have got back to normal and may have something that works as well.
Good luck.
Old Nov 2, 2025 | 08:56 PM
Rich-L79's Avatar
Monster. Wouldn't use anything else on an LS.
