Pontiac GTO 2004-2006 The Modern Goat
basic info on GTOs
Old Mar 10, 2007 | 10:01 PM
eLTwerker's Avatar
Default basic info on GTOs
There's no stickies for this section.
I just have some basic questions on GTOs. Probably just pointing me in the direction of a link or something would suffice. I'm looking for displacement, intake, cam and head, weight, suspension, wheel/tires info for factory GTOs. Also, what exactly is DOD? Did it come on goats?
Old Mar 10, 2007 | 11:20 PM
flyin red TA's Avatar
2004 was the LS1, 05-06 are the LS2, google it and you can get all the specs.
Weight is somewhere between 3750-3800.
DOD = displacement on demand, and nope, never came on the GTO.
Old Mar 10, 2007 | 11:27 PM
batboy's Avatar
Displacement for the 04 is 5.7 liter and the 05/06 is 6.0 liter. The 04 is a LS6 intake. The 05/06 throttle bottle is drive by wire. The 04 uses casting # 241 heads while the 05/06 uses casting # 243.
Old Mar 10, 2007 | 11:51 PM
DeepBlueZ's Avatar
LS1 = 346 ci
LS2 = 364 ci
The LS1 uses normal 241 casting heads and a relatively tiny cam. The LS2 uses 243 casting heads (factory LS6 heads, better flow) and a slightly larger cam.
Before I lightened it up a little, mine weighed in at 3690 pounds without driver and with about a third of a tank of fuel.
wheels were either standard 17x8 with 245/45/17 BFGs or optional 18x8s with softer 235/40/18 bridgestones.
Old Mar 11, 2007 | 10:58 AM
Nsty98LS1's Avatar
they have some suspension issues. once that's cured you're in good shape
Old Mar 11, 2007 | 12:23 PM
oifish's Avatar
Is there something about the LS2 consuming oil? Ive heard something about that a couple times, I dont know how common that is.
Old Mar 11, 2007 | 09:51 PM
About as common as oil consumption on an LS1.
Old Mar 12, 2007 | 01:27 AM
DeepBlueZ's Avatar
there were a small handful of LS2s that suffered catastrophic failure from A LOT of oil consumption. However, the overwhelming majority either don't use any, or use a little here and there, but are within spec. (similar to LS1s)
Old Mar 12, 2007 | 10:39 AM
Fenster's Avatar
My buddy weighed his 06 A4 the other day... 3790 with him in the car!
Old Mar 12, 2007 | 12:58 PM
Rob's Avatar
Rob
'04 LS1 is the same as the '01-02 F-Body, right down to the cam.
'05-'06 LS2 is basically a '01 LS6 but with a different intake and bigger displacement.
My '04 weighed in at 3760(without me) when it was stock. Nothing taken out of it and a little less than a 1/2 tank of gas.
Old Mar 12, 2007 | 01:37 PM
Steel Chicken's Avatar
No, the oil consumption issue was more pronounced with LS2's.
Old Mar 12, 2007 | 04:27 PM
DeepBlueZ's Avatar
mine's about 3750 with me in it now...(still heavy as hell, but better than it was )
Old Mar 12, 2007 | 04:32 PM
00SS!'s Avatar
So what did you do/take out or whatever?
Old Mar 12, 2007 | 07:39 PM
radkon's Avatar
Here are the 04 specs:
http://konrademrich.com/cars/gto/gtospecs1.htm
http://konrademrich.com/cars/gto/gtospecs2.htm tire size is wrong on this one.
Old Mar 13, 2007 | 02:11 AM
DeepBlueZ's Avatar
Nothing drastic...
the car was 3690 when stock, (no driver, 1/3 tank).
- pulled y-brace (saves 13 pounds)
- lightweight HSV skidplate (saves 12 pounds)
- Boyd F22 wheels (saves 8 pounds at each corner)
- pulled jack/spare/chocks (saves 30-35 pounds, i didn't weight that stuff exactly)
- Exhaust mods (longtubes in place of stock manifolds, resonator replaced with X-pipe, magnaflow muffs which were NOTICEABLY lighter than the stockers, conservatively estimated at 10-15 pounds total savings for these.
overall total = savings of 97-107 pounds or so.
I rounded it out and called it 3600 even with no driver and same fuel level. I myself am the best weight reduction as I'm only 150 pounds.
I'll double check when I can get a chance to get the car back over to the scale I weighed it on when it was stock, but the above math is pretty reasonable.
Old Mar 13, 2007 | 08:59 PM
brandtdavis's Avatar
anybody have a stock dyno sheet
Rpms HP Tq
2500 x y
2600 x y
2700 and so on?? Somethign I can paste into excel??
thanks,
Brandt
