Pontiac GTO 2004-2006 The Modern Goat
Predator Programmer and Cat help
Old Oct 20, 2007 | 12:20 PM
squeals99's Avatar
Default Predator Programmer and Cat help
ALright my friend with an 04 gto just cut his cats off... and now he cant figure out how to shut the o2 sensors off to take the check engine light off with a predator tuner...
if anybody has an idea of what to do, please help
thanks
Old Oct 20, 2007 | 12:43 PM
GTOBOY's Avatar
O2 Sims
Old Oct 20, 2007 | 12:48 PM
squeals99's Avatar
so you cant just get the check engine light to be ignored or anything by the programmer?
or just make it to where the o2s get a reading with the programmer?
Old Oct 20, 2007 | 01:31 PM
2001NBMZ28's Avatar
Predator should be able to turn off the rear 02 codes. Have him go to diablosport.com and click on support, then forums.
Old Oct 20, 2007 | 01:43 PM
squeals99's Avatar
k thanks a lot guys! appreciate the help... hopefully we will get this business taken care of today
Old Oct 20, 2007 | 03:12 PM
GTOBOY's Avatar
Good luck
Old Oct 20, 2007 | 04:28 PM
jed.only's Avatar
i think the SLP version is the only one that can do that, but i may be wrong.
o2 sims will not work, the PCM looks for a variable voltage on the rears, not a straight 1/2 volt like earlier engines/pcms.
