Vararam OTRCAI for GTO
My thoughts exactly. Patrick(vararam) make some wicked ****....without a doubt,...anything this company makes,...i'm a firm believer in them. Every car I have installed a vararam on(Y body) they have all picked up 3-4 mph from a air intake mod.
Thats badass mang.
I got a few more pics from last week when they changed the floor of the box and sealed it. They also made a piece that comes over the radiator and covers the area in front of the radiator where it was catching some air and causing some turbulence. They then sealed that area to the hood as well. This was done last friday just to see if there was any difference in airflow over the radiator and into the air box. Seems to be working and it helped IAT's a bit. I will be going over there this Friday again and they may have a different box for me to try out. We will see.
I finally got an OK to show a couple of pics now. Keep in mind that this is nowhere near a production piece. This is just a prototype. This is also just one piece of the two that will make it into production. One piece (the piece shown here) will house the filter, and the other piece that is being designed now will connect to the base and go up and above the radiator and pull from in front. The filter is the same 4" filter that they use for the C6 Corvette. They want it to be able to support over 600rwhp naturally aspirated if possible and keep temps to within 10 deg. above ambient or better. As you can see the MAF is being used without any problems, and so far the drive-ability has been excellent.
