Pontiac GTO 2004-2006 The Modern Goat
weak points
Old Aug 26, 2008 | 02:37 PM
Coy's Avatar
Coy
Change the stock front radius rod bushings, rear spings, add drag bags, and get a good four wheel alignment.
That is my only problems with the stock suspension. I am also going to add one BMR stub to see if it helps with wheel hop. Some guys on the LS2gto apparently had good results with that, but I wouldn't be suprised if it doesn't fix anything.
Old Aug 26, 2008 | 07:20 PM
svede1212's Avatar
i'm pretty sure it was by running two different half shafts, one stock and one of the upgrade ones.
Old Aug 27, 2008 | 10:11 AM
GFORCE1320's Avatar
The weakest points with an 04 is the stubs and half shafts. The outer axle shaft is smaller in the 04's, they corrected it in the 05-06's. The 04 used some goofy outer cv joints too.
The stubs are the same throughout the years but still a weak spot.
I run cryo treated factory stubs and have been 9.70 with a 1.43 60ft time on them.
Come visit me on ls1gto.com about half shafts. I'm a sponsor over there.
Old Aug 31, 2008 | 01:55 PM
Coy's Avatar
Coy
That's what I was referring to. Thanks.
