Road Racing Road Course | Autocross
Replacement brake calipers
Old Feb 19, 2011 | 10:43 AM
HioSSilver's Avatar
Default Replacement brake calipers
Are the any good ones that would be better than stock? I've looked and have'nt found much.
Old Feb 20, 2011 | 10:57 AM
HioSSilver's Avatar
nothin available???
Old Feb 21, 2011 | 10:16 AM
mattf2's Avatar
not sure about fitting on stock brackets, but the c5/c6 upgrade isn't too bad to do. You end up w/ about 1 more inch of rotor diameter.
If you're looking to upgrade your stock setup, get better pads, put in a good hi temp fluid, and install stainless lines.
Old Feb 21, 2011 | 10:38 AM
SIK02SS's Avatar
StopTech makes a kit, Wilwood makes a kit, AP Racing makes a Corvette kit which I'm sure can be used, and Brembo makes a kit. Google is your friend on finding them all
Old Feb 21, 2011 | 11:20 AM
HioSSilver's Avatar
That's why I asked the question..I found nothing. I don't want bigger rotors just a upgraded replacement calipers. I have a set of 15's for drag strip duties and still want to use them. I all ready have pfc pads SS lines. The pedal has been spongy for a while and that's what happens to our race cars when the caliper gets ware on it. I thought there might be a better replacement caliper availible.
Old Feb 21, 2011 | 03:30 PM
SIK02SS's Avatar
not that will fit under 15s and they all require a larger rotor. have you bled the brakes? what do the rotors look like, uneven wear?
i don't know how you couldn't find any of them...
http://www.andysautosport.com/chevro...e_kits/brembo/
http://www.streetbeatcustoms.com/Sto...ke-Kit/797649/
http://www.streetperformance.com/par...-140-7763.html
http://hardbarusa.com/hardbar/produc...roducts_id=179
Old Feb 21, 2011 | 04:56 PM
HioSSilver's Avatar
Yes I have bleed them. I don't want those because A: they won't fit under my 15's B: they're heavey.
