Which tire size combo works best?
1. 315/30/18 at all 4 corners
2. 315/35/17 at all 4 corners
3. 315/35/17 at front and leave 315/30/18 on rear.
The 17's are $100 less per tire, 1/4" taller and 3/8" wider. I would need wider wheels at the front no matter what, but with different offsets would not be able to just rotate front to back without dismounting tires.
Anyone have any experience with sizes and results? I run nitto NT01's and very happy with them. Also, who makes a lighter weight wheel then the OEM Z06 replica's I am currently running, or at least a front lighter wheel with correct offset for a 10.5" wheel to match? Thx.
Whatever decision you make I'd go with a square setup so that you can rotate tires.
BTW, I have 245s all the way around now, and plan on going with 275/40/17s. This sizes seems to have the greatest variety of tires available. FWIW, I did a tour of the paddock during the June Sprints at Road America last year, and the GT1 cars all used a 275-width tire of some sort. If it's good enough for them, it's certainly more than enough tire for me.
Mine have been pretty good, I am on a 275 NT05 with a little over 1.0 camber on the front. I have Blaine Fab cooling ducts on the front which help them live a little longer by cooling the rotor from the inside out through the vanes in the center of the rotor outward, the cool air hits the center first then is directed outward into the rotor.
If anyone has a different experience, please share. With a more agreesive pad I am able to go into corners much deeper which has allowed me to stay on it in the straights longer. Add another 150hp with the new 416 and I'm seeing almost 10 more mph down the main straight (142) so braking has become more important then previously.
I'd like to find just a pair of lightweight 18" x. 10.5" wheels to match my black OE replicas Z06 wheels and run 18" 315 squared all the way around. Not sure of the offset needed for the front in that size though?????
I've ran mostly 315/35-17 square setup for my road racing, and have found it works well. I've used 295's up front and that has seemed to work well too. But running a fat tire isn't always the key to running fast laps. In Nasa, we have guys that ran a class that was a points based class. They got back some points by running skinny tires (245's) and used those points for other mods (brakes, headers, etc.) and turned some very fast times in doing so.
Also to consider, you have much more choices for big brake kits by running an 18" wheel than 17" wheels. I've been using Wilwood SL6 calipers on the front of my car and has been very successful for me. The pads are thick and they are cheaper than OEM pads too.
