Road Racing Road Course | Autocross
Accu-sump
Old Jan 16, 2023 | 08:50 PM
Nemesis 2000AD's Avatar
Default Accu-sump
Where are you guys placing / running your accu-sump set ups for road racing on your 4th Firebirds? Thinking running it down in the front left fender where the cruise control is. Nice and close and easy plumbing. I seen one pic on the forum, but their got to be more than one picture out there.
Old Jan 17, 2023 | 08:51 AM
Supercharged111's Avatar
I'm guessing yours is a street car? I was gonna suggest somewhere inside depending on what's already inside.
Old Jan 17, 2023 | 12:10 PM
Chris Paveglio's Avatar
Well I don't road race and don't have actual impact concerns for the most part, but on my street & AX car, mine is behind the radiator and in front of the serpentine belt, crosswise. I have an electric valve, and FWIW it requires a lot of maintenance IMO. I've had this for 19 years and I've replaced the valve 3x in that time, seems like they start to fail after a while, IDK if that's age or amount of use (or not use).
Old Jan 17, 2023 | 08:13 PM
Yes, it's street car, when you say inside, do mean inside the frame rails or inside the interior (I have full interior, and still do cross county trips to as many good roads as possible - tail of the dragon, needles 16a, pikes peak, etc) - the road racing is High speed autocross with Midwest council - It's basically a drag race of one lap of a given track - Blawkhawk, road america, gingerman, milwaukee mile, etc. It's a safe way to race a street on track and if you spin out your not too worried about hurting the car to bad.
Old Jan 17, 2023 | 08:37 PM
I have my power steering cooler there (below the rad behind the rad scoop / air deflector) and it a perfect place for that kind of cooler (think rock crawler, don't need lots of air flow, relieve on surface area), I have a small but long oil cooler in the sweet spot of air flow to the rad (that 4" wide high flow area at the bottom of the rad). I have a vacuum can (learned my lesson on turn 1 of Road America about having enough vacuum remaining for the power brakes - I normally did smaller tracks before that) mounted below the driver side head assembly (Trans Am) that I'll move to the pass side. I was going to mount another square puller fan assisted oil cooler in the open driver side remaining air open below the headlights, and mount the accumulator next to the cruise control motor along the frame which keep the plumbing simple. Any thoughts?
